Syvecs I/O expanders
Charlie
Syvecs Staff- Tea Boy
Post by Charlie »
Product and Description are attached for the Syvecs IO10
Retail price is £600 plus vat
Syvecs IO10.pdf
(150.49 KiB) Downloaded 1893 times
secure
Re: Syvecs I/O expanders
Post by secure »
Great!
Can we use GPS modules now? When will be the new firmware update for S6? Android and ios support?
Ryan.g
Syvecs Staff - Caretaker
Post by Ryan.g »
The I/O10 fully supports also on the S6, Custom Can pass through to allow Existing Dashes to work via using the 2nd can bus output on I/010.
S8's + this does not apply as multiple buses are available on ECU.
Ryan.g
Post by Ryan.g »
secure wrote:Great!
Due to how fast we push the Can Bus on the slave protocol to allow logging on external items up to 500hz!! We are looking into ways we can implement the GPS Module into the bus without causing problems. It will get done but with release for the new bluetooth modules which will be available as soon as Apple clear the Software on Itunes. Android to follow and does not require all the Auth that Apple does
Ryan
