I have setup the S6 PNP to go in limp mode when oil pressure is below target. Now I want to know where to setup the limp mode, as I am assuming this is possible?
Thanks in advance,
Mark.
						Limp mode configuration
Re: Limp mode configuration
Hi Mark,
You have a Rev Limit for LIMP Mode: Limiters --> Rev Limit --> Engine Speed Limit in Limp Mode
In case you have DBW you can also set a DBW Max. Target for LIMP Mode: Drive By Wire --> Limp Mode limit
Jasper.
Jasper.
Hi Jasper,
I have looked for a rev limit in limp mode, as I expected it to have this, but overlooked it......
Thanks!
Thanks!
Anyone knows how to get back from limp mode?
I set the oil temp limit to say 100
Car goes into limp mode when transmitter reachs 100c but not back into normal mode even I set the time 100 seconds. What do I miss?
Yes cycle the power off and on.
