When you are in Scal and for example in Run-Mode Fuelling/Base Injection 4 and you press SHIFT+F2 or F3, etc and you see a green circle with a number enclosed, next to the map.
What is that number representing in the green circle and how can I go back to not seeing it?
I came across while experimenting with Scal but not sure what is representing.
Thanks alot.
Scal Question
Scal Question
- Map.JPG (381.06 KiB) Viewed 14550 times
Re: Scal Question
Creates function key hotkey shortcuts, listed under "Cal->Edit Shortcuts"
Re: Scal Question
Ok great thanks alot, Paul
