Spare injector output to switch cooling fans
markssupra
Post by markssupra »
Hi all, is it ok to use Injector 8 output to switch twin rad cooling fans through 2 relays. I don't have any spare PWM outputs left on my S6.
Can the injector ouputs be programmed to monitor the coolant temperature?
Re: Spare injector output to switch cooling fans
injector outputs are still generic PWM outputs
So yes it can control a fan, Fuel08 CTL-76 assigned to the fan1/2/3 as you wish to trigger a relay or two
