Map & Traction settings saved?
Moderator: Wez
scott
Post by scott »
Just a quick question. If I shut down the car in cal 5 and trc 7, when I start the car up will it default back to 1 & 1 or will it keep the previous values?
Just wondering if I can set it and keep the same setting without having to re-connect to bluetooth etc.
Piv
Re: Map & Traction settings saved?
Post by Piv »
Hi Scott,
If you haven't got any cal switches and only change map from the bluetooth module then it will go back to 1 and 1
scott
Post by scott »
I do at the moment but unfortunately I don't have any spare inputs so I would need to use the switch ones.
scott
Post by scott »
My main reason for asking is due to the security option of having a "dead" map so that the car won't start. I guess I could just make it the first cal setting though, that would take care of that :D
Downside of a bluetooth connected "occasional" interface IMHO.
You need - again, IMHO - permanently connected CAL switches or a Dash/Toucan/whatever that will ensure the CAL settings you want are present in all circumstances.
scott
Post by scott »
Thanks Tim, definitely some food for thought then :)
scott
Post by scott »
Just one more thing. Are you saying that I'm better keeping the switches and not using the bluetooth at all, or is there a way to use both at the same time?
It would be one or the other, as ultimately both connect to the analogue voltage inputs on the ecu for control.
Personally I like a switch I can see and change quickly at any time without a second thought and you'll always know what it is set at.
Tim's Cal switch with the numbered rotary dial make this very easy, although there will be various knob/dial options if these didnt suit
http://www.jti.uk.com/product/cal-switches/
Wez
Santa's Little Helper
Post by Wez »
As already mentioned the current Bluetooth firmware does not record last or allow to set a default cal / trc position, it defaults to 1 on startup / power on.
When Pat has some free time this is something we are looking to address, the idea being that you can set any position as a module startup position for all three outputs available, the hardware has the capability and we have already discussed the logic, just waiting on the implementation ;)
