I've found a bug with the new software.
I'm running Windows XP with the start bar (usually at the bottom of the screen) at the left hand side. When you maximise the Scal or Sview apps some of the window is hidden behind the start bar and there is a gap on the right.
The work around is straight forward, just de-maximise the window and position it manually.
Screen shot attached.
SSuite Bug Reports
Jez
- Horsham Developments
SSuite Bug Reports
- solaris.jpg (74.31 KiB) Viewed 24294 times
Re: Latest Solaris PC Software Suite
Or put the Start bar back down the bottom where it belongs
Re: Latest Solaris PC Software Suite Bug Reports
I think there is another bug on TOGGLE LOCK too. If you select to view both graphic and textual view it works without any problem. If you select just textual view it is not locking.
Jolly Green Monster
on vista I have to reinstall everytime for comms to work with ecu.. seems to be afterr a reboot..
Simon
Simon
Jolly Green Monster
fixed.. I presume it was a vista issue and latest microsoft download fixed it.. well problem gone anywayJolly Green Monster wrote:on vista I have to reinstall everytime for comms to work with ecu.. seems to be afterr a reboot..
Simon
