syvecs S6 GP
syvecs S6 GP
Is the S6 GP from 2011 exact the same board as the current board? The casing is much bigger then the current casing.
Re: syvecs S6 GP
I'm sure functionality is 100% the same, even if boards may not be 100% the same although they probably are.
The earlier casings were very generic and quite large. Think they changed around 2013 or so ?
I'm sure if you really wanted, you could have the casing swapped
