Issue is that the OEM CAS (Cam Angle Senssor) on the RB26 gets very inaccurate at high revs (120 or so trigger wheel apparently?), the question I have to ask in terms of the compatibility of the Cam Trigger Sensor Kit I have and the S6Gp is:
"Does the ECU support direct spark and sequential injection with a 24 minus 1 trigger on the cam?"
If you haven't figured it out by now, Mechanics is my strong point, not electrics
Need to know if this will work on the Syvecs or if I need to spend more money on a different kit that works on the Syvecs S6GP.
Thanks,
Russell
