my car is 92-96, with ignitor module  do i have to wire ecu to this or straight to the coil packs ?
i am running a set of tm works coils .
if you do will anyone help with pin outs on the ignitor i could work this out maybe but any help would be appreciated very much .
thanks gazza
						solaris on subaru coil questions
Re: solaris on subaru coil questions
The S6 has TTL level ignition outputs which are the same as most OEM ECUs these days, and is therefore incapable of driving ignition coils directly without the use of an ignitor module, you should therefore keep the existing module unless planning on rewiring the car. The TM Works coils are, from memory, 3 pin items which would have integral ignitors like the later OEM coils on the MY01- models and therefore could be driven directly from the S6 if the original ignitor is bypassed, the TTL signals fed directly into the coils, and a new ground to the coils is provisioned.
pat thanks for reply again yes tm coilpacks have 3 pins as mine do .
i am rewiring the car totally yes on with it now ,
as i am aware 2 of the pins are 12v , other is earth .
i would like to loose ignitor yes but how would these coils wire up ?
might give paul a ring where i got them from .
also can you send me that cal we spoke about over phone to my email gazza2.5@hotmail.co.uk
also might need your help with dccd control via email if you dont mind helping
thanks
thanks
Hi Gaz,
As Pat suggests I would convert the TM works coils back to the OEM pin connection. You may need to unsolder the wires on your coilpacks and tidy the spades so you can fit the OE connector on, or altenatively put flying connectors on the coils and use a 3 pin connector of your choice, although orignally I just earthed the earth pin onto a ring terminal and used 93-96 2 pin connectors to join the coils to the engine loom.
Hope that's not too difficult!
