Info / help
Coxo
Info / help
Post by Coxo »
hi guys I have a mk2 rs and am trying to get flatfoot
Shifting working apparently it only works once to do a launch but it’s still not working I have looked at all the setting and it looks like it’s on but am not sure for it to be
Activated is it depending on something else.
How to I have it active all the time is my question
Trickster
Re: Info / help
Post by Trickster »
Sounds like you are mixing up launch control with flat foot shifting. Your car is obviously setup for launch control but the flat foot shifting is done through a gear cut request, which is setup by whoever does the calibrating for you
Graeme
Re: Info / help
It works great on any type of gearbox/engine set up.
Here is one on a conventional old school syncro box and a manual throttle cable.
https://www.youtube.com/watch?v=9ifLP-dUqPI
