More water / meth injection
Hyundai RM-19 prototype with some 'familiar parts' :)
LR WI set up.jpg (647.8 KiB) Viewed 243671 times
It's certainly overdue !
The dedicated water injection feature is rather lacking.
Gpro
Post by Gpro »
I too look forward to seeing more advance water injection features in Syvecs!
Trickster
Post by Trickster »
Unless you are on S6 😔
Trickster wrote: Fri Jun 05, 2020 5:56 pm Unless you are on S6 😔
You can still do custom tables and do water injection well, and safely with an S6. If you have one input and a spare output...job done.
Trickster
Post by Trickster »
Yeh I know mate, I was just being funny because there are no more firmware updates haha
Now doing full integration with Dash/ECU, running complete strategies to measure flow/s, status, and per bank or rotor control.
Basics are:
*low flow
*high flow
*differential flow
*Solenoid fault
*Pump fault
Other items to follow....
wiStatus 1500cc per rotor.jpg (202.12 KiB) Viewed 242933 times
Simulation testing the control logic, all works
Maths used is allot more than posted above but hope it helps people interested in doing this.
Final Solution counters all Leak Block or Differential detection limits (Bank 1 Bank 2) or in this case per rotor ;)
dirrerential flow status error.jpg (930.09 KiB) Viewed 242921 times
perfect WI test.jpg (919.34 KiB) Viewed 242921 times
So have they finally allowed frequency inputs on the ecu, or did you have to do a workaround ?
stevieturbo wrote: Mon Aug 10, 2020 5:45 pm So have they finally allowed frequency inputs on the ecu, or did you have to do a workaround ?
To do the control items I showed an example of above you need the maths ability of a LR/Syvecs D4/D5/D8 dash unit.
For the frequency input currently need the use of both ECU and dash and wheel speed B channels used on ECU. It is down on the list to allow generic frequency input ability though.
Other power circuit related stuff I am using the PDUx3 states and the D4 dash to give status of the high speed valves and WI pump.
