Hi
.I am receiving lamda reading and wondering if its possible to change this to afr readings ?
I have a wideband lamda
Lambda to afr
Re: Lambda to afr
just open up the gauge and change the units to whatever you want.
Re: Lambda to afr
Assuming you mean in software, Right click on the gauge and choose "change units"Jacko996 wrote: Wed Jun 23, 2021 5:42 pm Hi
Re: Lambda to afr
Pet hate of mine...WHY OH WHY use AFR!!! Lambda is fuel independent. AFR is meaningless unless you know the precise fuel mixture, which is hit and miss with pump fuel at the best of times.
Stick with lambda units, IMHO
Re: Lambda to afr
resolution ease of use.
AFR IS easier.
AFR IS easier.
Re: Lambda to afr
This is a misconception spread out there sadly.TimH wrote: Thu Jun 24, 2021 7:54 pm Pet hate of mine...WHY OH WHY use AFR!!! Lambda is fuel independent. AFR is meaningless unless you know the precise fuel mixture, which is hit and miss with pump fuel at the best of times.
Stick with lambda units, IMHO![]()
AFRp (or could be dogshit) as a unit is totally irrelevant, Its just an arbitrary scale as Stevie says just use what has meaning to you end of story.
The only people it has relevance to is engineers so if you want to back calculate things like thermal efficiency or bsfc or mass used per unit of time etc then its of relevance especially to size specific items in the fuel system, you still need to know details of the fuel type to work any of those items out but to most 'tunas' they only are interested I have found in setting the fuel and for this the units that make sense to them is more important than some ones miss guided 'opinion' saying you are wrong. In this case as I have said 1 jizzilion times makes no difference if you are in petrol AFR scale or not, if you feed it Nitro methane or methanol or E85 or Yak Semen.... it will still be reading what it does (oxygen) and putting it into a scale you understand, and the understanding part is what is important more than anything else. Bit like giving a person a tape measure in metric units and they only understands imperial, no point making an old dog learn new tricks, he will still shit on your lawn
2 decades ago we were setting up some engines running on methanol with 35% nitro methane, there was no requirement to know nor did anyone need to know what the stoich AFR was for that specific fuel, the owners did not understand Lambda had no feeling for it, but they knew AFRp scales well, so gave them guidance based off that. Just as you say Lambda is independent so too is AFRp, metric or imperial tape measure, same deal.
I personally get a hard on for equivalence ratio, it makes much more sense than anything else does since were talking in fuel terms NOT air! Remember you are adjusting a fuel table not a farking air table
Re: Lambda to afr
If you want to convert lambda to a multiplier, as in your table its simply 1/Lambda * 100 (for percent)
As an example you use 0.7 lambda and state it being a more meaningful when viewed as 42.9% excess fuel (than compared to a lambda of 1)
But to really quickly see where you are in Lambda, (1/Lambda)*100= 42.9.
Lambda is then useful to use to quickly achieve what fuel multiplier you might need to apply to achieve a certain target.
Another way of using this is to say you have current reading of 0.9 lambda, you need 0.8, but how much more fuel do you need to apply?
Current: 1/0.9=1.11
Wanted: 1/0.8=1.25
Work out the difference, 1.25-1.11=0.14 multiply buy 100, and you have 14% as the multiplier you need to apply to the section of the map that requires it.
Current: 1/0.9=1.11
Wanted: 1/0.8=1.25
Re: Lambda to afr
Equivalence Ratio example
13% to 15% excess fuel, again makes allot more sense and is the simplest to use too.
Re: Lambda to afr
Isn't that showing lambda, as "mix"?
Re: Lambda to afr
Nah, frogs love to talk in equivalence ratio.
0.870L to 0.885L is about right for a maximum power setting.
