S6+ TPS dips from 97 to 91% for a quick second this has never happened before I have a code low voltage or ground is there a fix for the issue.
GTR
AMS throttle bodies
48 pounds of boost
TPS dip
Re: TPS dip
new setup ? old ? other ?
I presume it has worked previously ?
Does it do it every single time you have the throttle open ?
Datalogs of the event ?
mechanical throttle or DBW ? and do all blade position sensors reflect this "movement" ?
