GDI Injection Angle Tuning
GLDN6
Post by GLDN6 »
Hello,I am currently tuning a direct injection.
Now I have to adjust the injection angle. What is the best way to proceed?
How do I determine the perfect value? Actually
The perfect value should be where the lambda control regulator goes down, right?
e.g. WOT, Lambda 0.80 with 0% control, as soon as you set the angle 20 degrees later
and the lambda remains value but the regulation goes in -10% is that is the right way?
what tricks do you have to do so for tricks?
Cheers GLDN6
Re: GDI Injection Angle Tuning
Would it not be a case of monitoring burn efficiency, exhaust gas analyser, along with any torque changes etc ?
