Latest Base Map
Technical Help / Firmwares for the VAG MQB4 Range of AWD Controllers
Locked
Latest Base Map
The latest VAG MQB4 AWD Base map which matches the latest firmware can be found below in Attachments
MQB4 is only available on the X4 Hardware
This base map limits the Max duty to 70%, Some users of the Rs3 Kit from Iroz motorsport have the duty limits at 80% or even 90%. You will need to adjust in Scal to Suit
AwdBase_MQB4 1.24 X4.SC
(55.78 KiB) Downloaded 4110 times
1.25
AwdBase_MQB4 1.25 X4.SC
(61.05 KiB) Downloaded 4657 times
Re: Latest Base Map
AwdBase_MQB4 1.27 X4.SC
(66.87 KiB) Downloaded 2402 times
Re: Latest Base Map
The latest VAG MQB4 AWD Base map which matches the latest firmware 1.28 can be found below in Attachments
AwdBase_MQB4 1.28 X4.SC
(72.44 KiB) Downloaded 2051 times
Re: Latest Base Map
The latest VAG MQB4 AWD Base map which matches the latest firmware 1.29 can be found below in Attachments
AwdBase_MQB4 1.29 X4.SC
(72.89 KiB) Downloaded 2382 times
Locked
Return to “VAG MQB4 Range - Golf R7, Audi S3”
