Changes since 1.18
V1.19 Output Testing added
Firmware Version 1.21 - www.syvecs.com/downloads/AWD_Yaris_1-21-1.enc
						Latest Firmware Releases
1.23 Firmware - X4
Changes since 1.21:
OLD BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/AWD_Yaris_1-23-1.enc
NEW BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/X4AWD_Yaris_1-23-1.enc
Changes since 1.21:
1.23.3
Changes since 1.23.1:
OLD BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/AWD_Yaris_1-23-3.enc
NEW BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/X4AWD_Yaris_1-23-3.enc
1.24
Changes since 1.23.3:
OLD BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/AWD_Yaris_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/X4AWD_Yaris_1-24-4.enc
1.25
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/AWD_Yaris_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/X4AWD_Yaris_1-25-1.enc
Re: Latest Firmware Releases
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 - www.syvecs.com/downloads/AWD_Yaris_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 - www.syvecs.com/downloads/X4AWD_Yaris_1-27-1.enc
1.29 Firmware Release
Changes since 1.27.1:
* USB Datalogging
* Added Launch Mode
OLD BOARD - Firmware Version 1.29.1 - https://www.syvecs.com/downloads/AWD_Yaris_1-29-1.enc
NEW BOARD - Firmware Version 1.29.1 - https://www.syvecs.com/downloads/X4AWD_Yaris_1-29-1.enc
						* USB Datalogging
* Added Launch Mode
Changes since 1.29.1:
* Enable Load for Steering Angle Multiplier
* Option for AN1 to be BurnOut Switch or TransferCase Temp
* Transfer Case Temp Linearization and Limp
Firmware Version 1.34 - https://www.syvecs.com/downloads/X4AWD_Yaris_1-34-2.enc
Changes since 1.34.1:
* Added AWD Temp Diag CAN Stream for CANCHECKED Dash
Firmware Version 1.35 - https://www.syvecs.com/downloads/X4AWD_Yaris_1-35-2.enc
