VVT failure help please 2GR-FE
MikeyB571
Post by MikeyB571 »
Hi all, would someone be so kind as to take a look at this log file and help me to understand why the VVT went into limp mode?
It's a 2GR-FE engine with quad VVT and uses oil solenoids to control the cam angle.
Cam IO is:
Cam In 1 => AN05
Cam In 2 => AN07
Cam Ex 1 => AN06
Cam Ex 2 => AN08
The VVT error threshold is 10 degrees.
I can't see why it went into a failed state.
Any help appreciated.
2023-08-28 17-27-14 plus 0h08m54s S6#1097.SD
(429.71 KiB) Downloaded 1693 times
MikeyB571
Re: VVT failure help please 2GR-FE
Post by MikeyB571 »
Can anyone suggest addition values that I should be logging that might reveal why it's going into VVT Limp?
I know little about such things, but you are getting a load of spikes or something wrong on VVT2 inlet for whatever reason.
Maybe a sticky solenoid or something ?
The FB group always seems to get more traffic than here though
MikeyB571
Post by MikeyB571 »
Thanks for the feedback, I'll definitely take a look at the Facebook group.
You think that the vvt2 in actual angle is spiking?
That's interesting as I do suspect a wiring issue in relation to that, I've already swapped the solenoid out.
It would be good to know what the syvecs is actually tripping on still.
Thanks again.
could be a wiring issue. I've no idea what the triggering setup etc is you're using, nor would I be familiar with setting that shit up anyway.
The spikes seem unrealistically high numbers for actual cam movement, so it could be wiring related.
