Egine trigger and Idle Stepper
For Toyota Technical Chat.
Mr. Y
Post by Mr. Y »
Hello guys.
I'm about installing S6GP on 2JZ-GTE (non-vvti).
Can't you tell me how to wire S6 idle stepper outputs to OEM stepper motor and configure it?
Same question about crank position sensor... Some kind of base cal would be great.
Thank you in advance, hope this will save a lot of my time.
Re: Egine trigger and Idle Stepper
Hi Dennis
The wiring for the standard stepper motor is part of the loom adaptor and the base cal with the unit has the idle stepper all set up and some base duty values.
But if you want to see how the wiring is done on a Non vvti supra here is the pinout sheet i work from attached below.
Ryan
Solaris Main Pin - Supra&MR2.xls
(93 KiB) Downloaded 2712 times
