This thread is for tracking the firmware builds of the AWD Porsche 991 units. When a new release is available it will be added to the end of this thread.
Latest Firmware Releases
1.18 Firmware
Changes since 1.15
1.18 - Added simple Map locking and Restriction option. - Press C, F inside a map
Firmware Version 1.18 - www.syvecs.com/downloads/AWD_Porsche_997_1-18-1.enc
Changes since 1.15
1.21 Firmware
Changes since 1.18
V1.19 Output Testing added
Firmware Version 1.21 - www.syvecs.com/downloads/AWD_Porsche_997_1-21-1.enc
Changes since 1.18
1.23 Firmware - X4
![Image](www.syvecs.com/downloads/X4R35997.jpg)
Changes since 1.21:
OLD BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/AWD_Porsche_997_1-23-1.enc
NEW BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/X4AWD_Porsche_997_1-23-1.enc
Changes since 1.21:
1.23.3
Changes since 1.23.1:
OLD BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/AWD_Porsche_997_1-23-3.enc
NEW BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/X4AWD_Porsche_997_1-23-3.enc
1.24
Changes since 1.23.3:
OLD BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/AWD_Porsche_997_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/X4AWD_Porsche_997_1-24-4.enc
1.25
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/AWD_Porsche_997_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/X4AWD_Porsche_997_1-25-1.enc
Re: Latest Firmware Releases
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 - www.syvecs.com/downloads/AWD_Porsche_997_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 - www.syvecs.com/downloads/X4AWD_Porsche_997_1-27-1.enc
1.29 Firmware Release
Changes since 1.27.1:
* Usb Datalogging
* Added 996 option to 997 controller (Set CarCode to 3)
* Programming Fix
OLD BOARD - Firmware Version 1.29.1 - https://www.syvecs.com/downloads/AWD_Po ... 1-29-1.enc
NEW BOARD - Firmware Version 1.29.1 - https://www.syvecs.com/downloads/X4AWD_ ... 1-29-1.enc
* Usb Datalogging
* Programming Fix
