TinyDashv2 S7 CAN2 Set up
The Syvecs 2.4 Inch TinyDash is a compact competitively priced display designed as an easy to install and convenient source of vital information from your powertrain control system.
Re: TinyDashv2 S7 CAN2 Set up
If you aren't transmitting anything on the Plex CAN in the GPS slots etc, then no reason it should interfere.
But again, the main reason I bought the Plex micro DLG https://www.plex-tuning.com/product/ple ... n-display/ was I wanted a small screen, but also it has a built in 100 Hz GPS and Accelerometers to feed back into the ecu.
In that respect it's a bit of a bargain compared to other GPS units out there.
Jackstrath
Post by Jackstrath »
Defiantly something il look into, i need something with GPS and IMU!
Jackstrath wrote: Wed Nov 12, 2025 11:55 pm Defiantly something il look into, i need something with GPS and IMU!
Obviously you could buy that unit specifically from Syvecs, or their new Bluetooth GPS unit etc. But their GPS is kinda pricey, not much less than the Micro display which is also a GPS/IMU !
It was just a no brainer for me. By comparison, my old SDM500 which was also a GPS unit was near double the price of the micro.
Return to “Syvecs TinyDash”
