NTK Lambda Sensors for L2C
The Syvecs Lam2CAN is an 8 Channel Laboratory Grade NTK Lambda sensor interface with comprehensive onboard fault logic. It also includes dual dedicated exhaust pressure sensor inputs enabling compensation for the effects of exhaust pressure on the lambda measurement. Data from the Lam2CAN is then transmitted via CAN to provide fast and accurate data to engine control units and external dataloggers.
Thought this might be of use to put up here.
I have been using a host of NTK sensors on the L2C all of which have worked well.
  • 4mA
various model numbers
  • 6mA
Each type has its place with varying benefits, for those who want to read a bit about what I have done there is a few pages in this link, been going at it on the ECU side for over 10 years and on the L2C since the early prototype boards, one of which I still have going on my cal bench.
Testing and calibration of sensors > http://www.syvecs.co.uk/forum/viewtopic ... &start=140
