DBW Learning Mode
chrisheadlam
DBW Learning Mode
Post by chrisheadlam »
I have a S8 with DBW, but have upset the throttle butterfly by accidentally jamming it. Now sCal shows PPS Fault in the Errors and the DBW is disabled. I have corrected the original faults but can anyone guide me as to how to use DBW Learning Mode in sCal to reset the TPS / PPS with Pedal Position Learning?
Re: DBW Learning Mode
PPS is pedal position, TPS is blade.
So if it's a PPS fault it should not be related to the DBW unit itself.
chrisheadlam
Thank you. I will digest that and see where I get to
