LATEST CONFIGURATION(Mapping) SOFTWARE
Locked
LATEST SSUITE AT BOTTOM OF POST
The Below Link is for version 321 (OLD) PC Software with USB Support
Version 321 - Right Click - Save AS
OLD! SEE 332 IN NEXT POST!
Install the SSuite package onto your computer and 6 Programs will appear:
• SCal - Used to adjust the maps in the ECU (Calibrate it)
• SCfg - Used to setup the datalogging (Configure which channels and events to log, and how frequently)
• SData - Used to read datalogs from the ECU
• SView - Used to view and interpret datalogs
• SMon - Used to monitor live ECU parameters
• SMsg - Used to monitor ECU status and debug messages
• SDash - Used to Setup D5 Dash
• SPdu - Used to Setup Power Distribution Modules *Coming soon*
Manual can be found here
http://www.syvecs.com/downloads/Syvecs_Manual_V1.1.pdf
List of Recent Changes/Fixes
SCal – 2.15.316 to 2.15.321
Widen ability to display item values in HEX
Support for more complex menu security
SCfg – 2.15.64 to 2.15.65
Improved export to TXT file
SDash – 2.15.299 to 2.15.307
Support for dash main code 1.4.12 to 1.4.16 added
new checkbox added to LOGGING tab to set logging or Ecu streaming to internal flash (MMC) rather than USB
major overhaul of LinearisationDialog (more like SCal with grid control)
Add new GUI on DISPLAY tab to set both full name and tab name (abbreviation)
Add new GUI on display tab to GOTO page
Add RX datastreams for PduX2 to CANrx tab
Add support for linearisation of CAN voltages - ONLY - 5V at 1mV/bit
SView – 2.15.240 to 2.15.243
Multiple device messages that occur very close to one and other are now combined into a single tooltip on the traces display. Previously it was possible to miss some of the messages.
Text annotations can now be added from the session menu in addition to a double clicking in the traces area.
bugfix –worksheets that included XY plot with 2 Y axes saves in error, invalidating whole workbook
PduXSetup –2.15.1967 to 2.15.1978
There has been a relatively rare but persistent problem with the previous release whereby under certain circumstance a calibration once saved or programmed could not be read back by PduXSetup.
A number of bugs have been found since that last release that could cause these corruptions.
In addition to fixing those bugs, corruption detection has now been built into PduXSetup.
During editing process, the calibration in intermittently checked for corruption.
If found the UNDO buffer can be used to revoke recent edits and take the calibration back to a point where it can be safely saved to disk.
Corruption detection is now also performed immediately before saving or programming.
PduXSetup’s calibration reading has been made more tolerant of some of the errors leading to a previously unreadable file. Now more often than not most of that file can be recovered.
Add IO Summary Dialog
list details on all assigned soft and hard inputs and outputs
provides method to GOTO specific IO item in schematic
provides export to CSV of all IO details
Simulator improvements
add SimulationReset - for power cycle simulation
bugfix - simulator's handling of ALARM state in hard output
bugfix –Correct action of RESET component, should only clear FAULTed outputs
Calibration validation
bugfix - wrong soft output index reported when CAN assignment not found in schematic
bugfix - add validation of properties of EventIn and StateOut
Custom CAN
Add import of LR ECU Generic CAN transmit datastream from ECU calibration
Output Properties Dialog
make more of effort to highlight edit control in focus if text also highlighted
Bugfix - tooltip help text corrected when soft start selected
Major overhaul of Linearisation Dialog (more like SCal with grid control)
Re: LATEST CONFIGURATION(Mapping) SOFTWARE
The Below Link is for OLD Syvecs PC Software with USB Support and USB Logging
Release 2.17.1
https://www.syvecs.com/downloads/Syvecs ... -10-25.exe OLD VERSION
https://www.syvecs.com/downloads/Syvecs_Manual_V1.1.pdf
SCal 2.15.350 to 2.15.360
Updates
• Updated USB library
• Add ability to acquire profile from internet during USB demuxing
• New CANBUS monitor / capture facility for root connections only on device menu, Requires ECU main code firmware 1.755.4 or above
SNetServer – 2.15.94 to 2.15.97
Features
• On startup, add warning of any softlocks that are due to expirein next 14 days
• Add menu entry to display the list of softlocks due to expire
Bugfixes
• Prevent Z key triggering “Destroy Softlock” in Identity security dialog
• Adds new baud rate control for CANBUS only devices
• Adds ability to allows user updates from IDs with no root access flags
SView – 2.15.266 to 2.15.270
Features
• Max time gap between concatenable files can now be calibrated
Bugfixes
• When launched from command line, last accessed file not stored properly
Bugfixes
• CSV import
The Below Link is for the LATEST Syvecs PC Software with USB Support and USB Logging
Release 2.17.11
https://www.syvecs.com/downloads/Syvecs ... -01-17.exe
SCal 2.17.3 to 2.17.11
Updates
Features
• Support for new profile
• CM Map renaming feature
• Clearer SaveAsText output on Item and CalMap access dialogs
• Null names no longer allowed on renamable sensors
Bugfixes
• Switching between learn and base map
Features
Bugfixes
Features
• Popup stats tooltip on focus item in channel keys
o Min, max, average and standard deviation for data in view
• New options dialog for annotations and stats tooltip
Release 2.17.22
https://www.syvecs.com/downloads/Syvecs ... -09-15.exe
SCal 2.17.12 to 2.17.22
Updates
Features
 TAB in EditEnumDialog toggles between all possible values and those currently used in map
o Highlight currently used values in full list
 SensorDB only read when 2dStrategy displayed for first time (only user of sensorDB)
 Reword message box indicating RTC drifted too far from PC time
Bugfixes
 Fix possible ASSERT on GetRTC
 When importing SRL in cal/access/itemAccess, set min and default frequency
 SensorDB – one bad sensor could prevent the next loading
 Tag maps whose dependant maps do not fully import
 Better detection of recursive calls in MATH functions
SCFG – 2.17.7 to 2.17.8
Features
 Get and SetRTC now match implementation in SCal
SView – 2.17.11 to 2.17.14
Features
Bugfixes
SDash – 2.17.16 to 2.17.23
Features
 make GEAR selection criteria more flexible by not checking MIN and MAX if ENUM exists
 move loading SensorDB to LinearizationDialog (same fixes as in SCal)
 Support for new main code 1.12.0 (enhanced closing curtain effect)
o Option for 2nd closing curtain colour on DISPLAY tab
 Support for new main code 1.13.0 (enhanced GPS CAN receive)
o GpsLatLongSyncTime setup on MISC tab for max gap in ms between a lat and long CAN frame to be
considered same sample
 Support for new main code 1.14.0 (enhanced MATH)
o MATH for dynamic background image set on DISPLAY tab
o AG50 GPS lat and long default to 6 dec places in degrees
Bugfixes
 comparing cals where item in SCAN datastream have been deleted
Locked
