Latest Firmware Releases
Technical Help / Firmwares for the VAG MQB Range - Audi RS3 / TTRS
This thread is for tracking the firmware builds of the AWD Audi MQB units. When a new release is available it will be added to the end of this thread.
1.14.2
This is the first public release level
Firmware Version 1.14.2 - www.syvecs.com/downloads/AWD_Audi.enc
1.15
Version 1.15 contains the following updates
*Change Light Output Pin (HBR4)
*Drive ratio calculation for Gear detection on Manual Trans cars
*Enable Gear Detection from Drive Ratio option
*Change Light Min Speed
*Change Light RPM
*Change Light Min Tps
Firmware Version 1.15.2 - www.syvecs.com/downloads/AWD_AudiMQB.enc
1.18 Firmware
Version 1.18 contains the following updates
Changes since 1.15
1.16 - Added CanLogging option - New software will be released soon which allows you to monitor and log the canbus via USB
1.17 - CarCode Map Added for 997 Platform
1.18 - Added simple Map locking and Restriction option. - Press C, F inside a map
Firmware Version 1.18 - www.syvecs.com/downloads/AWD_AudiMQB_1-18-1.enc
1.21 Firmware
Version 1.21 contains the following updates
Changes since 1.18
V1.19 Output Testing added
V1.21 Output mode on changelight output to Lowside, Yaris HandBrake disable test mode light on dash in Burnout, Gear displayed in breakpoint, MAP1 Multiplier, post shift Multiplier to help stop spin after drivetrain torque change
Firmware Version 1.21 - www.syvecs.com/downloads/AWD_AudiMQB_1-21-1.enc
1.21.3
Version 1.21.3 contains the following updates
Changes since 1.21.1
* Handbrake is based on position NOT Switch. So can be used for holding Burnout
Firmware Version 1.21 - www.syvecs.com/downloads/AWD_AudiMQB_1-21-3.enc
1.23 Firmware - X4
Changes since 1.21:
V1.22 - Adjustable the Yaris display bars vs duty to match more OEM, SnowMode on the R35GTR selects AwdSel3
V1.23 - Added Gear Duty Multiplier
OLD BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/AWD_AudiMQB_1-23-1.enc
NEW BOARD - Firmware Version 1.23 - www.syvecs.com/downloads/X4AWD_AudiMQB_1-23-1.enc
V1.23.3
Changes since 1.23.1:
*Bugfix with AwdSel and key on
OLD BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/AWD_AudiMQB_1-23-3.enc
NEW BOARD - Firmware Version 1.23.3 - www.syvecs.com/downloads/X4AWD_AudiMQB_1-23-3.enc
1.24
Changes since 1.23.3:
*Added MQB4 Support on X4AWD Hardware
*Changed Burnout/2WD mode to take priority over Hold decay so 0% is applied instantly
OLD BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/AWD_AudiMQB_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 - www.syvecs.com/downloads/X4AWD_AudiMQB_1-24-4.enc
1.25
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/AWD_AudiMQB_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/X4AWD_AudiMQB_1-25-1.enc
Locked
Return to “VAG MQB5 Range - Audi RS3 / TTRS”
