Latest Base Map
Technical Help / Firmwares for the VAG MQB Range - Audi RS3 / TTRS
Locked
Latest Base Map
The latest VAG MQB AWD Base map which matches the latest firmware can be found below in Attachments
Please note this is only a base file for the device and we recommend you speak with your dealer about calibrating the unit based on the car setup.
This base map limits the Max duty to 70%, Some users of the Rs3 Kit from Iroz motorsport have the duty limits at 80% or even 90%. You will need to adjust in Scal to Suit
AwdBase_RS3 1.14.SC
(37.21 KiB) Downloaded 5766 times
1.15
1.15 Firmware Base Map
AwdBase_RS3 1.15.SC
(38.8 KiB) Downloaded 5465 times
1.18
1.18 Base map, must be used with 1.18 Firmware
AwdBase_RS3 1.18.SC
(42.89 KiB) Downloaded 5506 times
1.21 Base Map
For use with 1.21 Firmware
AwdBase_RS3 1.21.SC
(46.26 KiB) Downloaded 5368 times
1.23 Base Maps
For use with 1.23 Firmwares
AwdBase_RS3 1.23.SC
(51.46 KiB) Downloaded 5588 times
AwdBase_RS3 1.23 X4.SC
(51.46 KiB) Downloaded 5516 times
1.24 Base Maps
For use with 1.24 Firmwares
AwdBase_RS3 1.24.SC
(55.83 KiB) Downloaded 5354 times
AwdBase_RS3 1.24 X4.SC
(55.78 KiB) Downloaded 5418 times
1.25
For use with 1.25 firmware on X4AWD Units
AwdBase_RS3 1.25 X4.SC
(61.05 KiB) Downloaded 5502 times
Re: Latest Base Map
For use with 1.27 Firmwares
AwdBase_RS3 1.27.SC
(66.84 KiB) Downloaded 3522 times
AwdBase_RS3 1.27 X4.SC
(66.87 KiB) Downloaded 3626 times
Re: Latest Base Map
For use with 1.28 Firmwares
AwdBase_RS3 1.28 X4.SC
(72.44 KiB) Downloaded 3224 times
Re: Latest Base Map
For use with 1.29 Firmwares
AwdBase_RS3 1.29 X4.SC
(72.89 KiB) Downloaded 3648 times
Locked
Return to “VAG MQB5 Range - Audi RS3 / TTRS”
