Hello,
Has anyone or is it possible to setup a Grayhill brand canbus keypad with canopen eg a 6 button style to be connected into a syvecs ecu S7 can to operate, pushbutton functions like:
https://www.grayhill.com/productattribu ... 206-2RN3AG
logging on/off
different boost levels
rolling antilag momentary switch
cal map selections
traction control levels
Grayhill Canbus Keypad
Re: Grayhill Canbus Keypad
We can support these through custom firmware. You'd need to contact support.
Sounds good,
Trying to do it without using a pdu
You don' t need custom firmware to do this. You can reprogram the keypad to send data in a format the S7 or above can read on custom can import.
Is there any more information on how to do this? I’m looking to do the same.
Bringing this to the top.
I want to run a 15 position keypad in line with a S7i (new) and Pdu X3.
Does this work pretty seamlessly? Can I make the interaction of one button work on both units (button - 3 way Radiator On/OFF/ECU controlled). This would require both the ECM and the PDU seeing this and using logic
Here is a small video showing the WM pump driven by the PDUx3audpwr1 wrote: Fri Mar 04, 2022 6:26 pm Bringing this to the top.
and description of button programming........
https://www.youtube.com/watch?v=Hrj-PcnZVJs
