Latest Firmware Releases
100Hz GPS and IMU Module
Locked
Firmware 1.4 of the 50Hz/100Hz GPS Module is attached below.
Please use the Syvecs Updater program to load the ENC file. Guide here http://www.syvecs.com/downloads/Syvecs_Updater.pdf
ENSURE the GPS is sealed again if using in harsh environments with a silicon based sealant
The 1.4 Firmware fixes the following issues:
* Added support for 100hz new hardware
* Signed issue fixed on heading
* Speed Jumping issue fixed when stationary at high altitudes
1.5 Firmware
Firmware 1.5 of the 50Hz/100Hz GPS Module is attached below.
The 1.5 Firmware fixes the following issues:
* BugFix for 100hz IMU Data being 90deg out with New IC
SyvecsGPS100hz Lat Long Fix.zip
(18.24 KiB) Downloaded 2854 times
1.6 Firmware
Firmware 1.6 of the 50Hz/100Hz GPS Module is attached below.
The 1.6 Firmware fixes the following issues:
* Improvements for signal decoding in areas where sat data is limited
SyvecsGPS.zip
(18.4 KiB) Downloaded 1373 times
1.7 Firmware
Firmware 1.7 of the 50Hz/100Hz GPS Module is attached below.
* BugFix with IMU data for Bosch MM5 Stream
https://www.syvecs.com/downloads/SyvecsGPS_1.7.enc
1.9 GPS Release
Firmware 1.9 of the 50Hz/100Hz GPS Module is attached below.
The 1.9 Firmware fixes the following issues:
* BugFix with LatG and LongG CAN transmission drop
https://www.syvecs.com/downloads/SyvecsGPS_V9.enc
[*]Custom version for dual 500kb below[*]
https://www.syvecs.com/downloads/Syvecs ... CUSTOM.enc
Locked
Return to “Syvecs 100hz GPS / IMU Module”
