GDI 4 DI pump wiring
alackofspeed
Post by alackofspeed »
I would be very grateful for guidance on the attached CAL, as to which pins the GDI pump +ve and GDI pump -ve should be wired. HB4 is slaved to IGN12, and IGN12 is slaved to Fuel 12. Therefore am I correct to understand the GDI +ve goes to HBridge 4 (Pin 61), and GDI -VE goes to Fuel 12 (pin 32)?
I believe the LP fuel pump should be wired to H Bridge 3.
All help much appreciated. :)
1.660 GDI Ford Ecoboost 1.6l - ST180 Stock Engine Stock Turbo Stock Manifold - OBD2 - BASEMAP V2.SC
(579.39 KiB) Downloaded 1525 times
