NTK sensors
greg
NTK sensors
Post by greg »
Hello :) im looking for the most robust/long lasting NTK wideband sensor
Has anyone used one of these with the S6:
NGK / NTK Wideband O2 Sensor ( UEGO ) for Custom Applications - NGK PN 24300
I think its the one used for NGK Powerdex AFX
or would i be better off with an L2H2
Ive not used NTK's sensors before but the bosch LSU's ive used in the past havnt lasted very well.
I will be fitting these on various drift cars (which generally just get allot of abuse :twisted:) i would like to get something a bit stronger
thanks in advance for any help
Re: NTK sensors
Hi Greg
I have done a few cars now with he L2H2 provided from below
http://www.lambdasensor.com/main/mwide.htm
They are very well built and should last for a long time if installed in the correct location.
Need to fit them at least 20inches away from the Cylinder port or the hotside of the turbo. Heat kills mosts wideband sensors as well as condensation in the exhaust. So always try and mount in a vertical position so that the water can not run into the sensor.
Ryan
greg
Re: NTK sensors
Post by greg »
cheers Ryan ill give one a go
