Pwm fuel injector
The Syvecs WMI controller is a compact but very powerful unit for controlling a complete Water Injection electronics system, safely and correctly.
Lqqk
Pwm fuel injector
Post by Lqqk »
Is it possible to use a fuel injector (high impedance) with the Syvecs wmi? Have wondered based on the manual images?
Re: Pwm fuel injector
yes no issue at all, i would say an injector is better than most valves on the market
darksyde
Post by darksyde »
I want to use two injectors (one per bank on a six cylinder) with a F88.
Would it be possible to set up WMI as secondary injectors and assign the three cylinders of one bank to one injector output?
I would like to keep it syncronized to the crank, so the cylinders are getting an even distribution of wm.
no
darksyde
Post by darksyde »
So I am going to assign secondary injector outputs 1-6 to six outputs and wire three outputs for one bank together for the injector. Same for the other bank.
As they are open collector, can I just put the three outputs on one injector or should I use a diode in-line on each output of the ECU?
lilycollins9x
Post by lilycollins9x »
Yes, it is possible to use a high impedance fuel injector with the Syvecs Water Methanol Injection (WMI) system. The Syvecs WMI system is designed to work with injectors that are typically used for water methanol injection purposes, which are often high impedance injectors.
Monkey Mart
Lqqk
Post by Lqqk »
Started to play with this - any suggestions what frequency is the right starting point in the settings for a fuel injector?
Return to “Syvecs WMI Module”
