I'm going to wire up my k type thermocouple EGT sensor soon.
Just wondered how the linearisation worked - the sensor with out voltages in the mV range - and the linearisation is the usual 0-5v which is much too high /low resolution.
Does the Solaris already have a k-type curve built in, and only uses the 0-5v linearisation when using a 0-5v input?
EGT sensor
Re: EGT sensor
I asked the same question a litle while ago, just select k-type in the sensor setup, there is no calibration as the probes are calibrated.
Jez
- Horsham Developments
Re: EGT sensor
Cool, thanks Wez
I did search but egt is too short for the search function.
Re: EGT sensor
As Wes has said above but ensure that you wire the K-type sensor into Ther + and Ther -
Ryan
Ryan
Jez
Re: EGT sensor
Pat mentioned in another thread that you can wire k-type into the ther+/- inputs. I'll prob give it a go tomorrow.
Re: EGT sensor
Oops put unsure..... I ment ensure you use Ther + and -
I also used one of the Vems 6mm to 2mm EGT sensors jez and it works brilliant
Will edit the above
Will edit the above
Re: EGT sensor
Is it possible to connect a RTD egt to the EGT inputs? If so which values need to go in the linearization? It's a AEM sensor.
Re: EGT sensor
I have exactly the same question
Re: EGT sensor
RTD Sensor will work but needs to go into an AR input with pull up on.
Then setup the scaling to match the aem sheet
Re: EGT sensor
Ryan,
The AEM RTD calibration is temperature against resistance, and the ECU requires voltage.
What's the supply current? If I have that I can set up the calibration using Ohms law.
Cheers!
Tony
Cheers!
Tony
