Hi Gents,
I made a Pinouts PDF to visualize all Pins on the S8 ECU and have used colors to visualize all potential "Groups" of functionality.
Hope it provides some assistance to anybody making looms.
Jasper Kopinga
CS Racing
Taiwan
Syvecs S8 Pinouts PDF
- Syvecs_S8_pins.pdf
- Syvecs S8 Pinout
- (7.82 KiB) Downloaded 2428 times
Re: Syvecs S8 Pinouts PDF
Thanks Jasper, that's very helpful !!
---john---
---john---
Caveat emptor - for example, there is 16 fuel injectors in list, but 14 in location map.
There are 16 in both. 2 of the injector outputs are on low current pins.
There are certainly 16 Fuel Ouputs in the list.
As Paul mentioned 2 are on Pins #47 and #20 and since they are located close to Lam#1 and Lam#2 they are best used as Lambda Heaters and I'm quite sure that was what the designers had in mind
Jasper.
Jasper.
Yes, indeed - i just 'stared and counted those wider ones', so didn't notice.
tarmac terror
