Hi can anyone advise the layout of the 12 pin Nylon connector on the back of the S6PNP ?
I don't mean the function, just how it is layed out.
thanks ---john---
						PNP 12 pin connector - Layout ?
Re: PNP 12 pin connector - Layout ?
if you look at the rear of the connector, the wire side, that plugs in to the AUX connector (as if you're looking in to the back of the Syvecs) with the locking tab on top, then pin 1 is bottom right , pin 6 bottom left, pin 7 top right and pin 12 top left.
Thanks Tim !
Appreciate it !! ---john---
