FYI we have flex fuel sensors in stock, complete with 1.5m or 4m cables (engine bay mounting vs. boot mounting) and available with or without -6 fittings.
These are a great addition for any car running meth or ethanol fuel mixes as you no longer have to accurately mix fuel at the pump - the Syvecs flex strategy will interpolate between a pump fuel and a methanol/ethanol map seamlessly.
Contact us for prices.
FlexFuel sensors
Re: FlexFuel sensors
Is the General forum okay for pimping stuff?
Well...this is the JTi section of the forum so I assume it's OK. If not, I'm sure I'll get told.
aaaah i just saw the "general" !
Carry on!
Do you have them in stock ready to send?
Carry on!
No problempavlo wrote:aaaah i just saw the "general" !
Absolutelypavlo wrote:Do you have them in stock ready to send?
When i drain the tank and put pump fuel in after an event,
will this automatically adjust the mixture or swap maps?
It measures alcohol content - so if you're swapping between race fuel and pump fuel, or even 95RON and 98/99RON then it won't "flex" properly, as I understand it.CHRIS S wrote:When i drain the tank and put pump fuel in after an event, will this automatically adjust the mixture or swap maps?
The methodology is to map using your base pump fuel, then map with pump fuel + x% alcohol and setup the Syvecs strategy so it "flexes" between those two maps.
As an example, my own car was mapped on VPower, then on Vpower+15% methanol. As long as I don't ever exceed a 15% mix, the sensor and the Syvecs strategy mean I don't have to be overly accurate when adding methanol to the fuel.
Hi Tim
What I was getting at is I Race the Car on VPC85 then after the event I drain it and run pump fuel threw the motor and injectors ect
Will it automatically adjust the fueling?
If the ecu has been tuned correctly, then yes it should allow you to run pump through the E85 fuel without you making changes at the time.CHRIS S wrote:Hi Tim
