Requesting for Base Map of Subaru Impreza Sti (EJ20 / GDB-F)
flitzow
Post by flitzow »
Hello and good day,
I'm here indeed looking for the base map of S6 P&P for my Subaru Impreza Sti (EJ20 / GDB-F / MY05) Spec-C. It'll be required to be used prior to the tuning session. I've been informed that Syvecs has the base maps and thus hoping that any expert here will share it with me. TQ in advance.
The print screen link of base map request for Supra MKIV TT:
Re: Requesting for Base Map of Subaru Impreza Sti (EJ20 / GDB-F)
This is for a JDM car with a euro engine, standard injectors and vf35 turbo. It should only be considered a startup map, but has all the basics configured.
Check the comments for what inputs and outputs are physically attached to what pin.
01-Subaru01-05-1.33-NBo2.SC
(292.02 KiB) Downloaded 2090 times
flitzow
Post by flitzow »
TQ Pavlo...will do the necessary screening on this map prior to any tweaking..
Draven
Post by Draven »
Is this possible to get a base map for my JDM Impreza '05 with a S6 PNP.
It has 850cc injector's, Bosch 044 pump, LM500 billet, ej207 2.1 stroker.
Or can I use the above map? :?
