User defined outputs?
Bikey
Post by Bikey »
From having a look through the software, there do not appear to be any user defined outputs (ideally 2 or 3 axis). Am I missing something? Is this a possibility?
Thanks.
Re: User defined outputs?
There aren't really, but it would be great if there was.
What exactly do you need to control ?
Bikey
Post by Bikey »
I would like PWM control of the lift pumps in my saddle tanks. I can work off the main pump output, but I would like to reference each tank's level sensor and a flow sensor (so the relevant pump turns off when a tank is empty). At the moment it looks like I will need to handle part of this through my Race Technology data system (which has programmable PWM outputs)
I think I could come up with some others too, but controlling the pumps was the main one thus far.
