S6 pnp inputs
garyf
S6 pnp inputs
Post by garyf »
I want to free up some inputs on my ecu, load cell 1 is on AN12 which is connected to ac compressor so Im thinking I can just re assign this to fuel pressure with no Ill effects, the one Im not sure about is the lauch control switch which is on AN16 and connected to the neutral position switch, is the neutral position switch just used to confirm that the car is out of neautal for a lauch state? Or would re assigning this affect anything else?
Re: S6 pnp inputs
If you have a speed input signal, just dump the separate launch switch and use the Cal switch options and speed/tps/rpm thresholds to activate launch
That way no extra inputs are needed for launch.
garyf
Re: S6 pnp inputs
Post by garyf »
Great cheers Steve.
