Help re. Error Messages
peterguk
Post by peterguk »
If i look at error messages, i get this:
If i dismiss to clear the messages, they return.
However, in the live data screen, i get this:
So there are errors for MAP, battery and TPS
Yet in live data MAP value is correct, TPS is correct (and varies correctly i i open throttle, and battery voltage is normal.
So do i have errors or not?
Re: Help re. Error Messages
When you have an error it's colored as below, when its all green that means there is not an error as below.
