When adjusting an existing calibration for a new engine that will have an increased Rev Cut/Limit, are there any locations other than the engine speed breakpoints settings for Ignition, Fueling, VVT and Wastegate Control that require adjustment?
The 4 key areas that I listed above are the ones that come to mind, but want to ensure that I'm not missing anything.
Thanks for your assistance.
Adjusting Calibration for Increased Redline
ciphermonk
Re: Adjusting Calibration for Increased Redline
When you change the breakpoints, you can select to tag any map settings that may be affected so you can review and adjust if necessary.
ciphermonk
Thank you Stevie. That's what I did. "Proceed and Tag" and then went through each of the tagged maps and adjusted.
Just wanted to ensure that I'm not missing anything else. I'm still new to the Syvecs platform.
Appreciate your help.
