gp ecu wiring
scoobyphil1971
gp ecu wiring
Post by scoobyphil1971 »
I removed a full engine and ecu loom for a gp ecu from a version 7 and its been fitted into a version 2, pin6 sensor ground was connected to the dash clocks, is this a trigger earth? and were could I find one or connect too on the v2?
Re: gp ecu wiring
Any idea who made the loom ?
That sounds a little odd, do you know exactly where on the clocks it was connected ?
And are you absolutely sure it is pin 6 ?
