2008 Subaru does not start
west_minist
Post by west_minist »
Dear All:
I am running the S6GP PnP kit for the 2008 Subaru WRX/STI Hatchback.
When you turn the car on, the ECT gauge is high. When you try to start nothing.
Any idea what the issue can be?
FUEL 01, Cylinder 01 Primary Injector
FUEL 02, Cylinder 02 Primary Injector
FUEL 03, Cylinder 03 Primary Injector
FUEL 04, Cylinder 04 Primary Injector
FUEL 09, Tacho
FUEL 10, Starter Enable
FUEL 11, Wastegate 1 Control
FUEL 12, Air Con Control
IGN 01, Cylinder 01 Primary Ignition
IGN 02, Cylinder 02 Primary Ignition
IGN 03, Cylinder 03 Primary Ignition
IGN 04, Cylinder 04 Primary Ignition
IGN 05, Fuel Pump 1
IGN 06, Drive By Wire 1
LAMBDA V, Lambda Sensor 1
AB01 AN 01 (5V/BI), Crank Position Sensor A
AB02 AN 02 (5V/BI), Manifold Absolute Pressure Sensor 1A
AB03 AN 03 (5V/BI),
AB04 AN 04 (5V/BI),
AU01 AN 05 (5V/TH), Cam (Phase) Sensor / Cam (Inlet 1 Variable Valve Timing) Sensor
AU02 AN 06 (5V/TH), Cam (Inlet 2 Variable Valve Timing) Sensor
AU03 AN 07 (5V/TH), Cam (Exhaust 1 Variable Valve Timing) Sensor
AU04 AN 08 (5V/TH), Cam (Exhaust 2 Variable Valve Timing) Sensor
AV01 AN 09 (5V), Throttle Position Sensor 1A
AV02 AN 10 (5V), Throttle Position Sensor 1B
KT+,
AV03 AN 11 (5V), Pedal Position Sensor A
AV04 AN 12 (5V), Pedal Position Sensor B
AR01 AN 13 (TH), Engine Coolant Temperature Sensor 1
KNOCK, Cylinder 01 Knock / Cylinder 02 Knock / Cylinder 03 Knock / Cylinder 04 Knock
AR02 AN 14 (TH), Air Charge Temperature Sensor 1
AR03 AN 15 (TH), Air Con Switch
AR04 AN 16 (TH),
FUEL 13, Lambda Heater 1
FUEL 14, Sensor Warning Light
FUEL 15, Fan 1
FUEL 16, Fan 2
FUEL 05, Variable Valve Timing 1 Inlet A
FUEL 06, Variable Valve Timing 2 Inlet A
FUEL 07, Variable Valve Timing 1 Exhaust A
FUEL 08, Variable Valve Timing 2 Exhaust A
RUN STRATEGY WITHOUT PIN,
SLAVE1 AN #01,
SLAVE1 AN #02,
SLAVE1 AN #03,
SLAVE1 AN #04,
SLAVE1 AN #05,
SLAVE1 AN #06,
SLAVE1 AN #07,
SLAVE1 AN #08,
SLAVE1 AN #09,
SLAVE1 AN #10,
SLAVE1 AN #11,
SLAVE1 AN #12,
SLAVE1 AN #13,
SLAVE1 AN #14,
SLAVE1 AN #15,
SLAVE1 AN #16,
SLAVE1 AN #17,
SLAVE1 AN #18,
SLAVE1 AN #19,
SLAVE1 AN #20,
SLAVE1 AN #21,
SLAVE1 AN #22,
SLAVE1 AN #23,
SLAVE1 AN #24,
SLAVE1 AN #25,
SLAVE1 AN #26,
SLAVE1 AN #27,
SLAVE1 AN #28,
SLAVE1 OUT #01,
SLAVE1 OUT #02,
SLAVE1 OUT #03,
SLAVE1 OUT #04,
SLAVE1 OUT #05,
SLAVE1 OUT #06,
SLAVE1 OUT #07,
SLAVE1 OUT #08,
SLAVE1 OUT #09,
SLAVE1 OUT #10,
SLAVE1 OUT #11,
SLAVE1 OUT #12,
SLAVE1 OUT #13,
SLAVE1 OUT #14,
SLAVE1 OUT #15,
SLAVE1 OUT #16,
SLAVE1 OUT #17,
SLAVE1 OUT #18,
SLAVE1 OUT #19,
SLAVE1 OUT #20,
SLAVE1 OUT #21,
SLAVE1 OUT #22,
SLAVE1 OUT #23,
SLAVE1 OUT #24,
SLAVE1 OUT #25,
SLAVE1 OUT #26,
SLAVE1 OUT #27,
SLAVE1 OUT #28,
Re: 2008 Subaru does not start
Some info might help.
When you say nothing, what do you mean ?
No power, no starter, no engine, no what ?
west_minist
No start. The car uses a clutch switch to start. It is a key system and not push button.
No power to the starting motor.
When the ignition is turned on, the fuel pump is primed
That'll be one for Pat etc. Have you emailed support directly ?
west_minist
Yes I have.
west_minist
I had some issues with the harness, but sorted it out and re assigned the assignments in their correct locations.
While I wait for them, I will review the service manual for the starting sequence in conjunction with the ecu.
Is the CAN bridge present and programmed correctly? If supplied by Syvecs it should be, but if second hand it could be missing or the wrong bridge code present perhaps?
I've never done one with a Syvecs, but I did have issue with another brand ecu and keyless start. ( JDM model )
I did query Pat about the Syvecs version but at the time the customer didnt want to spend that sort of money.
Some comments from the email query at the time in case they are relevant.
"The normal way it works on a Syvecs is
that the starter will turn if you press the clutch within 30 seconds of
powering up the ECU, so long as the engine is stopped. If the engine
stalls then the 30 second timer is reset so it will start again. "
As I dont see a clutch input on your schedule there, I presume it must receive that via CAN, or is the starting a car feature, rather than the ecu feature somehow ?
He did mention on one car they re-wired so the push button was required to start the car.
But he would need to offer any detail around that
west_minist
TimH wrote:Is the CAN bridge present and programmed correctly? If supplied by Syvecs it should be, but if second hand it could be missing or the wrong bridge code present perhaps?
Yes. it is supposed to be CAN 2.0.
We want to use the Syvecs to control everything, including the DCCD. So the ability to pick up the G, yaw and Speed sensors were critical.
I review the service manual and I really do not see how the Clutch comes into play, except a trigger to the OEM ECU as a logic input condition for starting.
What is or maybe concerning, the ECT gauge on the dash reads high like when the car is in flashing mode when performing tuning of the OEM ECU. So some condition is not being met.
The CAN communication is all new to me and were and what to look for when using EMS is beyond me at this point for changes to be made.
I have another issue where the Lambda is not reading either, so I hope to have this all sorted soon with them. Lol I am all out of I/O on the S6GP.
One this that I noticed, when I was unplugging the ecu to return to OEM, the plug with the SSM communication (Connector B on Syvecs doc) came out. did not clip in it seems. My daughter came down sick so i could not stay to test.
The reason I asked about the CAN bridge is that I have a vague recollection that if the CAN is not setup right, then the ECT reading weirdly is one of the symptoms.
Have you been provided with a base map that includes the CAN datastream setup required for the hatch PnP kit?
