From a discussion on another thread, is inputting gear ratios in RPM/KPH not an overly complicated solution to a simple requirement?
Would it not be easier and more accurate to be able to input teeth numbers so the ecu does the calculations for you? Change a diff or a drop gear and change one figure in the ecu rather than recalculate everything.
Steve
Gear ratios
Re: Gear ratios
its far easier as it is
watch this > https://www.youtube.com/watch?v=qdtEvyg7Uxc
I used to teach this theory to apprentices and I tell you none of them had any idea of power flow's! and what they did to pass a test was soon forgotten
Re: Gear ratios
sicup2 wrote:From a discussion on another thread, is inputting gear ratios in RPM/KPH not an overly complicated solution to a simple requirement?
Steve
The setup on the ecu is incredibly simple......does everyone know the exact number of teeth for every gear, final drive etc in their gearbox ?
And after you've given the ecu tyre sizes, sensor/trigger wheel arrangements....the ecu does the calculations for you for "drive ratio" for the gear input values.
No real effort is required from the user.
Re: Gear ratios
I must like complication...I thought working out the gear ratios was easy enough..
So the bit I didn't understand then, is once Tyre Circumference, Number of Teeth and Number of Teeth per input are set, I log Driveratio and use the figures logged in each gear to fill in the Gear Positon/Drive Ratio table? Or am I still missing something?
Steve
Steve
Re: Gear ratios
Either log drive ratio or view it and yes, enter the data.sicup2 wrote:I must like complication...I thought working out the gear ratios was easy enough..![]()
Steve
Obviously the speed related setup needs to be correct in order for the displayed drive ratios to be correct. ie. you need a correct speed reading.
