There is a manufacturing error in all loom adapters made by JTi for Syvecs, relating to the "comms" connector. For all looms fitted with the grey or white connector that carries RS232 and, in most cases, CAN bus, the RS232 TX and RX pins are reversed. This really only affects anyone using a standard Toucan cable with the modem-type connector on the cable, and needing to use RS232 rather than CAN bus.
The solution is to swap the RS232 TX and RX pins - I can provide the necessary information to sort this if needed.
Since this came to light, I have started attaching a "JT Innovations" sticker to the comms connector: if your loom adapter has the sticker, it is wired right: if not, it is wrong!
Syvecs loom adapters made by JTi - RS232 wiring error
Jump to
- Syvecs Engine Control Systems
- ↳ General Syvecs Chat
- ↳ S6 GP/PnP Technical
- ↳ S6-I / S6Plus Technical
- ↳ S7-I / S7Plus Technical
- ↳ S8 Technical
- ↳ S12 Technical
- ↳ Syvecs Bluetooth Module
- ↳ Software
- ↳ Calibrations
- ↳ Technical Deposit
- ↳ Projects
- General Technical Forums
- ↳ Subaru
- ↳ Mitsubishi
- ↳ Toyota
- ↳ Nissan
- ↳ Porsche
- ↳ Dyno Talk
- ↳ Track Days
- ↳ VAG Technical
- Expanders
- ↳ X10 (Legacy - Gen1)
- ↳ X10 Gen2 Expander
- ↳ X20L Gen2
- ↳ X4 Gen2
- ↳ OEX - Oem Ecu eXpander
- Syvecs AWD Modules
- ↳ General Questions
- ↳ VAG MQB4 Range - Golf R7, Audi S3
- ↳ VAG MQB5 Range - Audi RS3 / TTRS
- ↳ Porsche 991.1 / 991.2
- ↳ Porsche 997.1 / 997.2
- ↳ Huracan / R8
- ↳ Nissan R35GTR
- ↳ Infiniti Q60
- ↳ Yaris GR
- ↳ CorollaGR
- ↳ Generic AWD Module
- Syvecs Accessories - GPS | Bluetooth | KT8 | Wifi | WMI | DI12 | Lam2CAN
- ↳ Syvecs 50hz GPS / IMU Module
- ↳ Syvecs 100hz GPS / IMU Module
- ↳ Syvecs KT8
- ↳ KT8 Rev3 Standalone
- ↳ Syvecs Wifi Module
- ↳ Syvecs WMI Module
- ↳ Syvecs DI12
- ↳ Syvecs Lam2CAN
- Syvecs Dashes
- ↳ Syvecs TinyDash
- ↳ Syvecs Edition Plex Dashes
- ↳ Syvecs D5 Dash
- Enhancements
- ↳ Feature Requests
- ↳ Request for Comments
- JT Innovations
- ↳ Toucan Display
- ↳ General
- Feedback
- ↳ Website feedback
