Syvecs Android App Chat - BETA Now Available!!!
Moderator: Wez
Tidgy
Re: Syvecs Android App Chat - BETA Now Available!!!
Post by Tidgy »
Hmmm couldn't see em. Was having issues I think the app with the menu out and not closing.
I'll do the old delete and renowned load and install.
Um as far as the other bit, uh pat, help!!! Lol
That bit went over my head. I'm up to clinic on Sat so can ask pat to check if that helps?
Tidgy
Post by Tidgy »
Slight update, removed the app from my phone and reinstalled and seems to have updated ok that time.
Can't see the oil temp/pressure though?
Wez
Santa's Little Helper
Post by Wez »
Tidgy wrote:Slight update, removed the app from my phone and reinstalled and seems to have updated ok that time.
Hiya, I have checked and you are right, Oil temp / pressure is missing from that build, I am planning to push another build out and will make sure they are included along with a few others.
Tidgy
Post by Tidgy »
So had a chat with pat and we had a look at what's going on.
First thing there seems to be a glitch with the menu staying open, only way we found to close it was to reset the whole software so loosing all the settings.
Second thing was indeed the assignments were incorrect so that sorted out the readings, due to the menu issue they were lost straight away though so need to be reset again.
Wez
Post by Wez »
Any chance you can send me a screenshot of the menu staying open issue, thats a new one to me.
Glad you got the assignments sorted, obviously having to reset is not going to work though.
Can you also take a screenshot from the device information screen within the app, should be under settings.
Tidgy
Post by Tidgy »
Wez wrote:Any chance you can send me a screenshot of the menu staying open issue, thats a new one to me.
should be attached.
Tidgy
Post by Tidgy »
other settings
Wez
Post by Wez »
Thanks.
I see it says live, do you get data if you enable the stream?
Tidgy
Post by Tidgy »
Data is coming through when the right setup is on there.
Wez
Post by Wez »
Tidgy wrote:Data is coming through when the right setup is on there.
OK great, I am looking into ways that I can try and capture the crash you are experiencing.
Can you give me a little more detail on what happens or correct me if I understand it wrong.
Sounds like you load the app from a fresh install, configure your assignments, start the stream and assign gauges and this is working?
What happens between this and the crash?
Does killing the app off from running in the background and simply restarting not fix the issue, do you have to uninstall the app and reconfigure?
