Latest Base Map
Technical Help / Firmwares for the Nissan R35GTR Awd Controller
Locked
Latest Base Map
The latest Nissan R35GTR AWD Base map which matches the latest firmware can be found below in Attachments
Please note this is only a base file for the device and we recommend you speak with your dealer about calibrating the unit based on the car setup.
AwdBase_GTR 1.14.SC
(37.21 KiB) Downloaded 5841 times
1.15
1.15 Firmware Latest base map
AwdBase_GTR 1.15.SC
(38.8 KiB) Downloaded 5379 times
1.18
1.18 Base map, must be used with 1.18 Firmware
AwdBase_GTR 1.18.SC
(42.89 KiB) Downloaded 5537 times
1.21 Base Map
For use with 1.21 Firmware
AwdBase_GTR 1.21.SC
(46.26 KiB) Downloaded 5483 times
1.23 Base Maps
For use with 1.23 Firmwares
AwdBase_GTR 1.23.SC
(51.46 KiB) Downloaded 5710 times
AwdBase_GTR 1.23 X4.SC
(51.46 KiB) Downloaded 5256 times
1.24 Base Maps
For use with 1.24 Firmwares
AwdBase_GTR 1.24.SC
(55.83 KiB) Downloaded 5490 times
AwdBase_GTR 1.24 X4.SC
(55.78 KiB) Downloaded 5470 times
1.25
For use with 1.25 firmware on X4AWD Units
AwdBase_GTR 1.25 X4.SC
(61.05 KiB) Downloaded 5138 times
Re: Latest Base Map
For use with 1.27 Firmwares
AwdBase_GTR 1.27.SC
(66.84 KiB) Downloaded 3407 times
AwdBase_GTR 1.27 X4.SC
(66.87 KiB) Downloaded 3340 times
Re: Latest Base Map
For use with 1.28 Firmwares
AwdBase_GTR 1.28 X4.SC
(72.44 KiB) Downloaded 2928 times
Re: Latest Base Map
1.29 Base map
AwdBase_GTR 1.29 X4.SC
(72.89 KiB) Downloaded 2079 times
Locked
Return to “Nissan R35GTR”
